| Kill Stories A place to share Hot Rodding lies...er we mean stories. |
Killed a cummins
Well it was actually mine.
I was driving my 99 dodge 2500 with the 24v in it headed to the world dairy expo right here in Madison Wisconsin and i got to the parking lot entrance and it died on me. It just shook and then died. I havnt had a chance to diagnose it yet but i have a feeling that my $1,400 injection pump went bad. Now i will have to add that to my $733 snow plow bracket, $347 high prformance lift pump and fuel lines, and $650 in tires, plus a shift kid and tranny fluid! Talk about a money pit!! Just so you know these 24v cummins motors are not as great as anybody says they are, mostly because of the vp44 injection pump. Sure the block and everything will last along time, but the rest of the motor isnt that great especially the fuel system. And my block is also the infamous "53" block which has had a history of cracking. I'm sorry i'm just venting a little bit and i wish i would have bought a good old 7.3l, instead of the cummins. On the bright side i get to drive my powerstroke even more now, until i get it fixed. I'll try to get some pictures up of my psd pulling my broken cummins. |
I was thinking the same thing tonight as I blew the doors off one with my good ol' 7.3 ![]() sorry to hear about your broke down truck.. but pics of it being towed by a ford would be a good conversation piece
Not to jack the thread but here are pics of me pulling my brothers Dodge 4dr LB Dually on a heavy *** bulldozer trailer with my '04 F-250 6.0L.
This was in the middle of the night one night. His truck dropped oil pressure to the turbo and it locked up. Truck and trailer weighed in at over 13.5k pounds not counting the weight of my truck too... http://i68.photobucket.com/albums/i2...ls_dodge_1.jpg http://i68.photobucket.com/albums/i2...ls_dodge_2.jpg http://i68.photobucket.com/albums/i2...ls_dodge_3.jpg Kinda crummy quality from my cellphone >< |
Sorry to hear about your troubles but pics would make it all better!
Thats what I heard. Everything around the block is made by dodge so thats promising.
If you dont mod it or tow heavy, your block mostly likely wont ever crack. The problem with those isnt so much the VP, but the lift pump. The VP is lubricated with the fuel, so the lift pump goes out, no fuel, thus no lubrication=failed VP. Other than that, theres nothin wrong with them. Bummer about your truck...has it been acting funny? If its all-of-a-sudden with no warnig, doesnt really sound like a VP...
bummer man -- sorry to hear about your problems -- but at least you have the PSD
An injection pump that has a history of failing because of bad lift pumps does not give the entire 24cv engine a bad reputation. That's like someone saying the 7.3's aren't as good as everyone says they are because the cam sensors go out all the time.
Yeah it has had a little bit longer crank time, lower power, but no dead pedal. I cracked the lines at the injectors and got no pressure so i checked powers and grounds to the ecm, and the fuel pump control module and had good ground and the right voltages. It has been getting 14 psi at idle and wide open throttle because i installed a walbro system, but i guess it was just a little to late to save it.
