Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Kill Stories
Kill Stories A place to share Hot Rodding lies...er we mean stories.
  #21 (permalink)
Old 08-12-2009, 04:12 PM
shu873 shu873 is offline
hillbilly keyboard racer
Originally Posted by PowerJoker6.0 View Post
sorry to jack but i was just wondering what 6.0 puts down stock and what it puts down with a custom tuned sct?
Originally Posted by WydOpen View Post
+1...curious as well.
Stock 6.0's rated at 325 at the flywheel. Actual RWHP on a dyno is around 250. A custom tuned SCT race file will get you between 400-425 RWHP, depending on the trucks strategy and supporting mods.
  #22 (permalink)
Old 08-13-2009, 07:24 PM
quicktospool69 quicktospool69 is offline
so did you race?
  #23 (permalink)
Old 08-14-2009, 02:15 PM
bouboy02 bouboy02 is offline
not yet, i havent seen him ill let u know when i do though
  #24 (permalink)
Old 08-14-2009, 04:18 PM
sounds good, you should make a vid when you do. its always fun to see a powerstroke hand out a good whoopin to a cummins
  #25 (permalink)
Old 08-26-2009, 06:08 PM
Melon Melon is offline
Yeah dude video it, thatd b awesome.... Good luck.... be sure to be safe about it or Granny'll get ya ...... lol
  #26 (permalink)
Old 09-01-2009, 02:54 PM
V8Strokin V8Strokin is offline
The 2nd gen. (98.2-02) 24valves only have 215hp at the crank. He could be making some good power with the stacked tuners, but there is no way he is going to be able to put it to the ground through the stock tranny. If he had a built trans I would be a little worried, but if its stock you shouldnt have a problem
  #27 (permalink)
Old 09-01-2009, 02:57 PM
Matt P Matt P is offline
a truck
With stacked chips on a 24v say edge comp and smarty you typically make around 350 or so
  #28 (permalink)
Old 09-01-2009, 04:29 PM
jefff929 jefff929 is offline
Stacking the Edge and Smarty isn't going to gain anything but too much timing if the programs are used together. The Edge could be used for gauges, but the J/A does most of what the Smarty does performance wise on a VP truck, so there isn't really a gain there. Stacking a TST powermax with the Smarty or Edge on a VP truck will work, but not Smarty & Edge. If he is using the J/A for gauges only then the Smarty is just a fancy code reader with the ability to change tire sizes and max speed.
  #29 (permalink)
Old 09-01-2009, 04:53 PM
a truck
Im not talking about a juice with attitude Im talking about an edge comp which you can stack with a smarty if you do just timing on the smarty
  #30 (permalink)
Old 09-01-2009, 05:33 PM
when i see him ill make sure it's safe and theirs not a lot of people around, i guess his transmission is about to go, and for a little bit of insurance im getting 155's put in just in case gotta make sure i do it right hopefully ill see him in a week ot two ill try to take a video of it
