KCR Members Map - Ford Powerstroke Diesel Forum
Keystone Coal Rollers Pennsylvania Chapter Area
Old 12-18-2009, 11:32 AM
KCR Members Map
OK HERE it is. Type in your address (you can just use your zip code if you want) then type in your info. (I put my truck info in my message line).
IF YOU WANT YOUR MARKER REMOVED FROM THE MAP
, pm me and I will remove it for you. Thanks Gruss
Old 02-02-2011, 12:38 PM
Guys I've cleared some names off of the members map, If your name got wacked in the process ,I'm sorry, but please check it and make your mark. Thanks Russ
