2 Power strokes/ 1st post - Ford Powerstroke Diesel Forum
post #1 of 25 Old 01-29-2007, 09:34 PM Thread Starter
Radkng's Avatar
Hi, this is my first post. I have been here to look around a few times but figured it was time to say hello.
I now own 2 Powerstroke trucks!
I bought a new (back in 1996) 1997 F250, 7.3, 4x4 super cab, XLT long box for hauling a camper and towing a boat. Still have it, 69k miles, motor is stock. Air bags and class 5 reese hitch for towing with camper. Great truck but family kind of out grew the super cab space.
Today I bought a 2002 F350, 7.3, 4x4, Crew cab, Lariat long box. 46k miles from the original owner. Very nice truck!
I will set the F350 up with air bags and class 5 hitch soon and eventually sell my F250.
This time I am considering doing some performance modifications.
Just interested in towing power for pulling hills with a huge load. I would like to boost towing performance and not cause damage to motor or trans. if that is possible.
Looking for advice, product recommendations, links to good information.
Thanks- Steve
Radkng is offline
post #2 of 25 Old 01-29-2007, 09:51 PM
back in the saddle
shu873's Avatar
to the site! I would have to say a good start for you would be to look at intake and exhaust. The 7.3's I'm told have a very restrictive stock air box. A lot of people around here run a DIY tymar set up, which uses a common filter you can get at NAPA or other auto parts stores. I believe the whole intake you can make yourself for around $50. As far as exhaust goes, 4 or 5" turbo back. A lot of different manufacturers, all are pretty good. That would be a good start I think... Hope this helps!
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 25 Old 01-29-2007, 09:54 PM
back in the saddle
shu873's Avatar
here's a good post on the tymar intake for you.
My version of the Tymar
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
post #4 of 25 Old 01-29-2007, 09:55 PM
gregor's Avatar
welcome to the site
you should post some pics
gregor is offline
post #5 of 25 Old 01-29-2007, 10:45 PM
straycat's Avatar
Welcome to the site Radkng, you came to the right place for the howdoi's. the first thing you want to do is gauges--Exaust gas temp--Boost--- trans temp. then the intake shu recomended above. check out Farmboy for a budget exaust, and you have your breathing taken care of. after that you can look into the power adders--programers--flip chips etc. I run the DP tuner, which lets me change on the fly (don't have to use the port to change the tunes ) just push a button. I have a 60 hp tow-80hp tow-80 econo-140 extreme-hi idle-as well as stock in my chip. but everybody has a preferance to what they want as far as a power booster goes. you will also want to look into the ATS vented turbo housing, these trucks have a problem with turb surge under load , and it is amplified as you build up the power in them. Check out ITP, one of the vendors at the top of the page, Dennis helped me out alot with my choice in the DP tuner. You will find that the vendors on this site will bend over backwards to help out, and give about the best prices you'll find as well. OK step one is done hahaha have fun and good luck
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #6 of 25 Old 01-30-2007, 03:48 AM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
Welcome to Powerstroke.org Radkng! Two Powerstrokes......I'm jealous.
'05 F250, CC, FX4, 6.0 PSD
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #7 of 25 Old 01-30-2007, 05:04 AM
welcome to the site, you will find what your looking for.
'O6 F350 Lariat XLT CC FX4, Arizona Tan with leather interior, all options except sunroof. 6.0/5 speed auto. Line-X spray-on Liner, and Chrome Appearance Group. SCT Xcal2 with looney tune
Future plans for turbo back exhaust, and
AFE filter.....just to "further enhance acceleration"
rhino49 is offline
post #8 of 25 Old 01-30-2007, 05:18 AM
im fat and ugly
stump0331's Avatar
welcome.............man at 69k miles that 97 model aint even broke in
2004 Excursion
stump0331 is offline
post #9 of 25 Old 01-30-2007, 05:42 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
to Powerstroke.org!
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #10 of 25 Old 01-30-2007, 05:58 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Looks like everyone has you moving in the right direction A Trans temp, Pyro, and boost gauge is pretty critical if your going to be towing. Your truck has a trans temp guage but its nice to have one that lets you see the actual temp in degrees F. Also a pyro will let you know how hot your exhaust gasses are before entering the turbo the magic # seems to be 1250 degrees F any hotter and you need to back out of the gas. The gauges are probobly the best way to stay out of trouble with your motor and trans. Go with a 4 inch exhaust and depending on what you want to spend I recommend the diy tymar its cheap and its more than what you really need for cfm's and you don't have to clean the filter. After that you can add the power modders either a chip or tuner. I have a tuner and like the idea of it being a code reader also, but shift on the fly would be a nice feature to have. Keep us posted on what you do and if you have any specific questions along the way we will certainly help you out
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
