Howdy from Laurel Montana - Ford Powerstroke Diesel Forum
Old 01-20-2007, 06:44 PM
Just purchased a 03 7.3 dully. Already got stuck in snow 3 times. Those 4 wheels don't like snow. Had an 02 Cheve 8.1 but I sure like this 100 0/0 more. It actually can pull. I pull a 34 ft. fifth wheel and the cheve 8.1 high end torque and 4-5K rpm going up mountains really was loud. Hope I have better luck with the Ford. Want to purchase a superchip just to use with the tow mode but everyone says change exhaust and get guages. Hoping to just use the tow mode for the pulling-not the speed. Thanks Barnyard
Old 01-20-2007, 06:55 PM
DKR DKR is offline
<--Pro Cooler Racer
Aboard the Forum!!
Old 01-20-2007, 07:09 PM
Send a message via AIM to SmokeN 12 ValvE
to the .ORG
Old 01-21-2007, 01:08 AM
---I think you will find a big difference, and as far as guages go, any tuner will increas the EGTs going up a hill. The gauges are to protect your investment in the truck, Too much heat can cause big problems. At the very least you should have a EGT and a Trans temp guage. the trans is the major week point in these trucks. For the extra money, it is worth investing in a chip like the DP or the Ts, they also addresse the line pressure, and shift points in the trans, as well as tc lockup, this goes a long way towards makeing your truck last longer. And once you do that----YOUR HOOKED---- you will want more-and more hahaha welcome to the Dark Side ---Hope that helps out some.
---Gord.
Old 01-21-2007, 05:07 AM
Gun Nut
Welcome to Powerstroke.org!
Old 01-21-2007, 05:13 AM
BIG TRUCK, SMALL DRIVER
Welcome to the Forum, Baryard!
Glad you're not having to suffer at the hands of a Chevy any more. You will never go back!
Old 01-21-2007, 06:55 AM
Is it even worth it???
to Powerstroke.org...
You've come to the right place.. best advice and answers I've found dealing with PSDs.
Old 01-21-2007, 08:53 AM
Welcome to the forum man!!! Im a montana naitive myself
Old 01-21-2007, 09:14 AM
im fat and ugly
wlecome aboard
Old 01-21-2007, 04:21 PM
The Fat Mod
To POWERSTROKE.ORG
