New from Hawaii - Ford Powerstroke Diesel Forum
Old 03-13-2009, 04:40 PM
Send a message via Yahoo to kanakagurl
New from Hawaii
Hi, we own a 2000 F-350 Powerstroke/Super Duty, 6 speed manual flat bed truck. It was running fine until the day following filling it up with deisel. We replaced the fuel filter and fuel pump and noticed there is no visible contamination. It now starts up good, but when reving engine at idle it only goes to 1500 RPMS. It also has excessive white smoke from the tail pipe and runs rough when accelerating. We were told it may be due to the Cam Position Sensor. Can anyone help me????
Old 03-14-2009, 08:48 AM
Is it even worth it???
Welcome to Powerstroke.org
Old 03-14-2009, 08:49 AM
Welcome to the ORG!
Old 03-14-2009, 08:52 AM
welcome to the org. nice sig pic. is the check engine light on? any fault codes?
Old 03-14-2009, 09:49 AM
No check engine light, no stored or presnt codes found
Old 03-14-2009, 09:51 AM
doesnt sound like a cps. but heres a for a tech
Sorry, thanks for the welcoming
Old 03-14-2009, 09:54 AM
So do I post a thread somewhere else?
Old 03-14-2009, 09:56 AM
ADMIN AND TECH
sounds to me like the screen in the tank ios clogged up, you still dont have fuel pressure probably
Old 03-14-2009, 09:57 AM
you could repost in the problem section. or try to pm one of the tech's. they have the green names. did you pull or change the fuel filter to see if maybe you got some bad fuel. or to see if your getting fuel to the filter.
