New from Wisconsin - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-01-2014, 11:30 AM Thread Starter
New from Wisconsin
REcently bought 95 F350. Had sat for yrs. parts missing from engine. Replaced vac pump, serpentine belt , map sensor, ebp sensor. batteries, tank selector valve, GPR and got it started with no check engine lite. Road tested, it , water in fuel lite came on and it died. Pulled tanks, cleaned , repaired screen , installed water seperator, Drained filter twice, Replaced filter. WIF lite still on but truck starts and runs at idle but will not accelerate until warm . Disconnected what I thought was wire to flapper by turbo. No change , Installed 205 thermostat, no change . Current problems are wif lite on, And no acceleration until warm. Might help to know how this electronic throttle works , Any advise appreciated.
ufdaland is offline
post #2 of 4 Old 05-01-2014, 10:04 PM
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
Glad to have you - to the ORG!!
One place to check out:
Ford Powerstroke 94-98 7.3L Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 4 Old 05-01-2014, 10:44 PM
Quoted: 725 Post(s)
Welcome to the ORG. I'll be heading up to Eden, WI this coming Tues.
Corey@CNCFAB is online now
post #4 of 4 Old 05-02-2014, 11:33 AM Thread Starter
I appreciate this forum, thanks for the replys, here is an update to my throttle problem. [ 95 F350] This morning I removed the pedal assembly to check the idle switch and get a good look at it in general. I checked it with a continuity meter and it seems to be working as it should . [no continuity until activated]. I couldnt see any problem with the wires to either connection so shot some WD 40 on contacts since I didn't have contact cleaner and reassembled. No change. Engine was cold - no response to pedal action. I then tried to drive it . 20 MPH tops. In about 1/2 a mile it started to get alittle better and then slowly came to life. Drove about 10 miles, engine warmed to center of gauge . This is the first time this truck has visited the center of the heat gauge since I have owned it . I wanted to see if once it was warm the problem was gone until the engine cooled. I stopped to fill with fuel , let it idle and when entering traffic lost throttle briefly but got it right back when I kicked the pedal. This could be dangerous in traffic. It still seems temp related but I don't know why or how.
ufdaland is offline
