Scratching my head??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2014, 08:34 PM Thread Starter
Send a message via Yahoo to Krazzyoddee
Hello everyone new to this site so bear with me. Hope someone might be able to give some insight. Had to rebuild my 6.0 loaned it to a friend and they returned it not working so well. Turbo gone. Hpop gone. Oil cooler gone. Two injectors and two melted pistons. Had a shop get it running Costed me $4000. Anyways rebuilt engine all stock oem parts. Put it back together and started turning it over. The only thing that isn't stock is egr delete. Problem is I kept turning it over to get air out of hpop system. Noticed oil leak found it oil leaking out of bypass tube on egr delete -- not good. My question is maybe it's the head gaskets or the oil cooler. Oil cooler is less than a year old. It was put on to get it running after I got it back from shop so should be good but so should the new head gaskets ??? Any help is greatly appreciated. I'm bout at wits end and broke from working on this truck.
2004 f250 king ranch ranch hand front and rear bumpers fx4 crew cab 6.0 all stock except egr delete and 4" straight exhaust.
Krazzyoddee is offline
post #2 of 5 Old 04-19-2014, 08:52 PM Thread Starter
Also is there any way to test the oil cooler off the truck? Can't get it to start from losing the oil and coolant. ???
post #3 of 5 Old 04-19-2014, 09:53 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Glad to have you - to the ORG!!
Check out these places:
Ford 03-07 6.0L Powerstroke Forums - Ford Powerstroke Diesel Forum - Good info!
Lone Star Powerstrokes - Ford Powerstroke Diesel Forum - Chapter for Texas Members
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 5 Old 04-19-2014, 10:21 PM Thread Starter
Thanks for the reply supercrutyps been looking through here all day. Lots of great info. Warily scatching though.
post #5 of 5 Old 04-20-2014, 11:26 AM Thread Starter
Pulled oil cooler out to inspect it and possibly test it found brass shaving in it. Could this be from the oil cooler or is it my hpop?
Tags
oil in coolant
