another new guy - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-12-2014, 06:17 AM Thread Starter
another new guy
Just bought my 04 f350 yesterday. All stock and looks all original with 243k on it. First plans are egr delete, head gaskets and studs. Then the basic upgrades. Not really looking for big numbers. I'll mostly lurk around the forums for a while.
4tun8 is offline
post #2 of 8 Old 04-12-2014, 06:26 AM
I just joined up after buying a 2000 F250 4x4 CrewCab with manual transmission. 117,000 miles. Pretty sharp. Already I've got problems with the emergency brake not holding, radiator has a leak and needs replacing, clutch position switch going bad, and a few cosmetic issues inside. I want to fix everything and delete the muffler. I might consider a chip but this is a daily driver and I average about 250 miles a day. About half of those are highway the rest are on county roads in the oilfield.
OklahomaRobert is offline
post #3 of 8 Old 04-12-2014, 07:06 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site...to both of you!
A lot of great info on the site and a BUNCH of guys that cant wait to help! Welcome!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 8 Old 04-13-2014, 06:57 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Welcome Aboard Guys, great info awaits!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 8 Old 04-14-2014, 07:53 AM
1ATony's Avatar
Quoted: 38 Post(s)
Tony
SHOP HERE FOR AWESOME
1ATony is offline
post #6 of 8 Old 04-14-2014, 07:20 PM Thread Starter
Well my truck is already sitting at my buddy's shop. The RF axle wasnt unlocked while in the free position. Last year the hub was replaced and wasn't installed correctly, most likely the spindle and hub will need replaced. Also the turbo needs rebuilt.
4tun8 is offline
post #7 of 8 Old 04-14-2014, 07:29 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
As long as the turbo dosnt need a major over haul they can be pretty easy to clean up. And a lot of times that's all that is needed. Check the videos out on you tube.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 8 Old 04-14-2014, 07:32 PM Thread Starter
I was told the rebuild kit is about 60 bucks. So far that seems like the cheapest part of this visit.
4tun8 is offline
