new with a few questions about the 6.0 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-09-2014, 05:51 PM Thread Starter
tnm
I just bought an 05 F250 and after driving it for a couple of weeks I checked my fuel milage. Far as I can tell it is all stock with only 57,000 miles. On the average all I got was 15 mpg. i would say about 75% of driving was on the freeway. (70 -75mph) Is this around normal? I was hoping it would be better. On another note I seem to be getting a vibration in the floor board around 1400 to 1800 rpm's. Transmission seems to shift fine. Any response would be helpful.
tnm is offline
post #2 of 8 Old 04-09-2014, 05:54 PM
shenanigans
junior125's Avatar
Quoted: 1441 Post(s)
Garage
have you gotten an Oasis report on it?
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is online now
post #3 of 8 Old 04-09-2014, 06:01 PM Thread Starter
tnm
Whats an oasis report?
tnm is offline
post #4 of 8 Old 04-09-2014, 06:02 PM
shenanigans
junior125's Avatar
Garage
Oasis report is something that you get from your local Ford dealer and it will show everything that was done by a dealer while the truck was under warranty
Mike
2005 CCSB F250 4X4
post #5 of 8 Old 04-09-2014, 06:10 PM Thread Starter
tnm
I'll have to check into that, thanks
tnm is offline
post #6 of 8 Old 04-09-2014, 06:13 PM
shenanigans
junior125's Avatar
Garage
once you have it, post back in this thread and either I'll try and help ya out or someone else will, also check out these links
General 6.0L Discussion - Ford Powerstroke Diesel Forum
The stickies there will be very helpful for any common questions you may have
Mike
2005 CCSB F250 4X4
post #7 of 8 Old 04-09-2014, 06:30 PM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 478 Post(s)
15mpgs with no tuner is on the bottom end of average from what Ive seen on here. W/o my tuner i get about 16. If you want better mpgs, get a SCT tuner and run it on street. I get 20 mpgs with that setting if I set my cruise on 70. Now remember I have stock wheels and a straight pipe. But look around on here there is just a million posts about making the 6.0 make u say
6.OHHHHH YEAH!!!
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is online now
post #8 of 8 Old 04-09-2014, 07:55 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
70-75 is going to get you up above 2k rpm. That's a great place to make power, but not great for mileage.
Check out the calipers front and especially rear brakes can drag. If you can monitor it, check the coolant temperature fully warm. It should be 188-194. If you see less than that it's time for a new tstat
These trucks like to be driven hard, but they don't need to be driven like that all the time.
Sent from one of the worst apps in the world
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
