2003 ford f250 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-11-2014, 08:22 PM Thread Starter
2003 ford f250
I have a 2003 ford f250 diesel 6.0
The speedometer and tachometer is
Fluctuating all over when in park or drive.
(Automatic). It seems to want to slip out of gear at times.
I replaced the speed sensor about 3,000 miles ago
For the mentioned problems. It has 104,000
Miles on the truck. It seemed ok for awhile and know
It has the same problems
Any help will be greatly appreciated.
Thank you.
Enduroerich is offline
post #2 of 3 Old 01-12-2014, 05:42 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 3 Old 01-12-2014, 12:38 PM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
Glad to have you - to the ORG!!
Check out:
Ford 03-07 6.0L Powerstroke Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
