99 f250 Powerstroke 4x4 - Ford Powerstroke Diesel Forum
Old 11-18-2006, 06:24 PM
ok so my 4x4 isnt locking in at all and i dont know what to do...is there a fuse for 4x4 or what do i need to do?
Old 11-18-2006, 06:31 PM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Is it that 4x4 isn't coming in or your hubs aren't locking? I'm assuming you have electroic shift on the fly (ESOF). Is the dash light coming on? Have you tried 4 Low?
Check your vaccum lines to the hubs. There might be a leak.
Without knowing exactly what you've tried, the sympoms, and your truck's configuration, it's going to be hard to diagnose your problem.
But, rest assured, you'll get all the help in the world here at the .org!
do you have manual hubs? or autos?
Old 11-18-2006, 06:33 PM
i have auto hubs..the light isnt comin on when i try to put it in 4low, i put it in N and then turn it to 4low and NOTHIN happens
Old 11-18-2006, 06:36 PM
have someone turn the knob while you climb underneath and tap on the shift motor on the transfercase with someothing hard. If it locks in while your tapping on the motor, replace the shift motor. Thats probably what you have going on. it could be a switch or wiring as well though, so dont just start replacing parts
Old 11-18-2006, 06:38 PM
Check the actuator on the Transfer Case. It might have come loose. Also...check all of your fuses under the dash, (behind the panel under the steering column). Also, try shifting into 4wd with the truck in park.
Old 11-18-2006, 06:39 PM
i tried it in park and same results...ill go check both the things you all have sad and let you all know..thanks alot guys
Old 11-18-2006, 06:42 PM
Also when i try these things do i have to have the truck started or can i just turn the key over? maybe a dumb question but didnt know..
Old 11-18-2006, 06:43 PM
key just needs to be "on"...truck doesnt need to be started
Old 11-18-2006, 06:53 PM
ok..so im looking at the truck as we speak..we got out one night and turned the hubs just incase...and you can turn it one way and it clicks like it locks or i can turn it the other way and it dont click which should both be on..
