Wow another newbie - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-29-2013, 10:58 PM Thread Starter
sabarnes's Avatar
Wow another newbie
Been watching and reading for a few months. Bought an 08 F350 Lariat CC ST 4 4 6.4L back in July. Had a 2500 gas but was maxed on Towing. F350 carries a 10,000lb fifth wheel so much better. While I'm new to diesels I have always been mechanical inclined so this will be a learning adventure.
sabarnes is offline
post #2 of 7 Old 12-29-2013, 11:08 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Welcome to the dark side and the org.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 7 Old 12-30-2013, 02:46 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
What Hitch are you using to pull the Cougar?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 7 Old 12-30-2013, 03:42 AM Thread Starter
sabarnes's Avatar
The truck came equipped for a goose neck. I had heard about the goose neck adapters to fifth wheel being real choppy so I went with the Anderson Ultimate gooseneck to fifth. Tows great with it. The best thing is changing from gooseneck to fifth only takes a couple minutes. So I can tow by all three types .
ID:	219858   Click image for larger version
sabarnes is offline
post #5 of 7 Old 12-30-2013, 07:49 AM
1ATony's Avatar
Quoted: 46 Post(s)
Welcome to the site.
SHOP HERE FOR AWESOME
1ATony is offline
post #6 of 7 Old 12-30-2013, 08:08 AM
SuperCrutyPS's Avatar
Quoted: 320 Post(s)
Garage
Glad to have you - to the ORG!!
Check out:
Ford 08 and newer 6.4L Powerstroke Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #7 of 7 Old 12-30-2013, 11:34 PM
HarvestingInternationally's Avatar
welcome to the org..nice rig
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
