Not to go new - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-29-2013, 08:44 AM Thread Starter
Question Not to go new
I have a 99 F250 that I've had for about 3 years. Last spring I had the turbo rebuilt and replaced the AC compressor and receiver. Other than that, no problems. I pull a 5th wheel that's around 11,000 pounds. I have no problem pulling but it does seem a bit heavy as it wants to bounce the back end some.
I have been looking at new and just a couple of year old trucks but can't bring myself to get back into a truck payment. So I have decided to keep the 99 and do some up grades.
The first one is air springs. The biggest question I have is removing a leaf or two out of the rear. I've only found one web site that's says to do so for better ride empty. As about ever 4 to 6 weeks I drive from Kansas to Ohio, I could use a softer ride when I'm empty.
The other issue I have is fuel economy. It has gone down some over the last 6 months, maybe since the turbo rebuild.
I will look on here for help in these areas and for other upgrades.
I would be very thankful for advise as this is my first diesel.
It's a 99 F250 7.3, Banks 6 Gun and 4 inch turbo back exhaust.
gdshepard is offline
post #2 of 6 Old 12-29-2013, 01:37 PM
SuperCrutyPS's Avatar
Quoted: 297 Post(s)
Garage
Glad to have you - to the ORG!!
Check out:
Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 6 Old 12-29-2013, 01:54 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You can get full air ride on the rear. THAT will be smooth.
Intake, exhaust, gauges, EBPV EBP sensor ICP fuel pressure and other things can give bad mileage.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 6 Old 12-29-2013, 03:06 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 6 Old 12-30-2013, 08:53 AM
1ATony's Avatar
Quoted: 33 Post(s)
Welcome to the site
SHOP HERE FOR AWESOME
1ATony is offline
post #6 of 6 Old 12-31-2013, 12:35 AM
HarvestingInternationally's Avatar
welcome to the org
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
