New Diesel Owner - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-26-2013, 12:05 PM Thread Starter
New Diesel Owner
Name is Marc. I just bought a new 13 ccsb f250 Lariet fx4. Moved up from a 12 Ram 1500. Love the truck so far. Any tips or advice welcome.
marc1982443 is offline
post #2 of 11 Old 12-26-2013, 02:19 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Regular Maint., drain water seperator, check coolant additive, replace fuel filter's and leave stock. Get yourself a good monitor like edge insight or similar to see whats going on with your engine.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 11 Old 12-26-2013, 04:07 PM Thread Starter
will the edge cst cause warranty issues? i plan on leaving stock except doing a lift tires and wheels.
post #4 of 11 Old 12-27-2013, 02:08 AM
Quoted: 4 Post(s)
Marc, no it won't because the CTS is not a tuner or programmer and doesn't alter the truck's computer in anyway. Think of the edge CTS like this, your truck is a computer console and the CTS is a monitor. Once you remove the OBD-II cable there is no footprint left behind. You will absolutely love this thing! You can have up to 8 guages at one time. Monitoring such things as HP, Tq, DPF load, EGT's, boost, coolant temps, and also program maintenance reminders. You can configure different background colors or use one of your own. The CTS is the best upgrade for a New truck bar none, and it won't void your warranty, trust me, I don't wan't to void mine on a $64,000 truck! Enjoy.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #5 of 11 Old 12-27-2013, 04:45 AM Thread Starter
Thank you for the info. I'm def going to look into one.
post #6 of 11 Old 12-27-2013, 04:49 AM
Quoted: 4 Post(s)
BTW, what color is your Scorpion?
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #7 of 11 Old 12-27-2013, 04:53 AM Thread Starter
Not the best picture.
post #8 of 11 Old 12-27-2013, 07:43 AM
Quoted: 4 Post(s)
That color looks good on the crew cab, lots of surface.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #9 of 11 Old 12-27-2013, 12:54 PM
SuperCrutyPS's Avatar
Quoted: 334 Post(s)
Garage
Glad to have you Marc - to the ORG!!
Take a look at:
Ford Powerstroke "Scorpion" 6.7 2011-? Forums - Ford Powerstroke Diesel Forum
Maryland Powerstrokers - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #10 of 11 Old 12-27-2013, 01:33 PM Thread Starter
i like it. truck needs a bath now though lol
