Sup Peeps!! Just Bout my 1st Diesel!! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-25-2013, 09:02 PM Thread Starter
Infinite's Avatar
Cool Sup Peeps!! Just Bout my 1st Diesel!!
Hey there Peeps! First Off, Merry Christmas! I just bought my 1st Diesel and am learning quite rapidly the differences between diesel and gas engines...Being a Ford fan and always wanted a good truck, i finaly had an opportunity to snag one up! Being new to this forum and to the Diesel community i dont know where to turn to find some help with my new baby. Im having trouble starting her in the am..from time to time..can anyone help point me in the right direction? Thanks Guys! P.S.: Anyone out here in West Texas??
Infinite is offline
post #2 of 10 Old 12-25-2013, 11:45 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
So....would you like to tell us what kind of truck it is? What's done to it? Any kind of maintenance record?
Your post wins most vague of the month.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 10 Old 12-26-2013, 12:45 AM
belz's Avatar
Quoted: 69 Post(s)
Welcome to the org and congrats on the new truck. Like stated above, without any info on the truck, you can't get any help.
Belz
CPA Director
belz is offline
post #4 of 10 Old 12-26-2013, 10:31 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 5 Post(s)
.....post up more info when you get a chance bud
-Julian
4th 6.fo
TwinTurboStroker is offline
post #5 of 10 Old 12-26-2013, 10:39 AM Thread Starter
Infinite's Avatar
Its a 2001 F350 Extended Cab Long bed. Straight exhaust with 5" Tip, HID's..but other than that...shes stock. She came with some kind of "tuner" i guess..looks like a knob that turns about 7 clicks clockwise. The higher it goes the more irratic she idles. Ill take some pics of her to post up here when i get a chance
Infinite is offline
post #6 of 10 Old 12-26-2013, 10:51 AM
usteffenhagen's Avatar
That's just a chip. Pull out the PCM to figure out what kind it is but unless you get it re burned, you won't really know what is on the chip. as for your starting issue... Probably just your GPR (glow plug relay) It's a common problem and when someone mentions the issues your having, I, along with most, jump to that. Just get it tested with a volt meter. How long to you wait to start it after the WTS light turns off?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #7 of 10 Old 12-27-2013, 01:40 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Glad to have you - to the ORG!!
A couple of places to check out:
Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum
Lone Star Powerstrokes - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #8 of 10 Old 12-27-2013, 08:21 PM Thread Starter
Infinite's Avatar
Great..Thanks!!
Infinite is offline
post #9 of 10 Old 12-28-2013, 05:53 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 10 Old 12-28-2013, 06:36 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site neighbor!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
