6.0 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-10-2013, 07:17 PM Thread Starter
Hello all just purchased a 2006 f350 6.0, after owning three V10s, still have one left, I purchased a 6.0, site has a ton of great info.
aczr8002002 is offline
post #2 of 4 Old 12-10-2013, 07:35 PM
RACERX's Avatar
Welcome, Go through It before It goes through you. Bullet proof It.
RACERX is offline
post #3 of 4 Old 12-10-2013, 09:03 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 12-10-2013, 09:07 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site. I had a v-10 and worked the snot out of that poor truck! Great truck but man it was thirsty!!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
