Hello - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-08-2013, 03:36 AM Thread Starter
Hello
Hello Everyone,
My name is Brandon. I joined today. I am a mechanic in the Army. I have been a long time diesel enthusiast. I have owned a 02 F-350 with a 7.3, A 05 GMC 2500hd with the LLY Duramax, and I recently purchased an 06 F-250 with the 6.0L. I look forward to reading through the threads and talking with all of you. Hopefully I can contribute as well.
Brandon
demarest652 is offline
post #2 of 4 Old 12-08-2013, 05:08 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site Brandon! And let me be the first to say thank you for being all you can be!!! I hope your somewere quiet and safe!!!
This would be a great place for you to start reading-http://www.powerstroke.org/forum/general-6-0l-discussion/259257-write-up-monitoring-6-0l-psd.html
Good luck and any question throw them out!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 4 Old 12-08-2013, 05:49 AM
Colin7.3's Avatar
welcome to the ORG!
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #4 of 4 Old 12-08-2013, 10:08 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
