Hello from LOUISIANA - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-25-2013, 07:20 PM Thread Starter
Talking Hello from LOUISIANA
Let me introduce myself. My name's Derek and I'm from Eros, La. I have a 2000 F250 FX4, 6 speed, 9" skyjacker lift with twin fronts, 37/13.5-17 Toyo Open Country M/T's, 5" turbo back straight pipe w/8" melon chuncker, and Edge Gen 1. I have to be honest, I'm fairly new to the Powerstroke world as I grew up in a GM family. But I must say that I LOVE the truck. Couldn't ask for anything better (glad I decided against the dirtymax). Anyway, the truck has 316,xxx-317,xxx miles on the odo, appoximately 500,xxx actual miles, and is still strong as ever. I am having minor issues, but they are expected. I am hoping to get some good advice from ya'll and doing the same in return.
Thanks,
Derek
Blowin'_Smoke
Blowin'_Smoke is offline
post #2 of 12 Old 11-25-2013, 07:30 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
WELCOME to the site! When you get a chance throw some pics up. How is the truck holding up rust wise being your down next to the ocean and all?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 11-25-2013, 09:02 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
Glad to have you Derek - to the ORG!!
Check out:
Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 12 Old 11-25-2013, 11:27 PM Thread Starter
Thanks guy's. The truck is rust free. I keep a good protective layer of mud on it for the most part. I actually just got it unstuck from my yard. I went to pull to the driveway from my "shop" and found a soft spot. Instantly sank to the frame even with it in 4wd. Three trucks later and a majorly screwed up yard it is finally out. All this rain and could weather we have been getting has things really messed up around here.
post #5 of 12 Old 11-26-2013, 02:03 PM
TheCody13's Avatar
Welcome to the forum. I live and work in Shreveport so you aren't that far away.
TheCody13 is offline
post #6 of 12 Old 11-26-2013, 02:44 PM
cletusjermal's Avatar
Quoted: 148 Post(s)
Not far from me either. I'm in bossier city.
2002 F350 7.3 4x4 SRW CCLB. GTP38R w/WW2 D-66, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust break and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #7 of 12 Old 11-26-2013, 08:14 PM Thread Starter
I'm hoping to get over yall's way soon. Harbor Freight and Bass Pro are calling my name...
post #8 of 12 Old 11-26-2013, 08:41 PM
theplumbingmedic's Avatar
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #9 of 12 Old 11-29-2013, 06:02 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 12 Old 12-14-2013, 03:45 PM
TheCody13's Avatar
You got a place you take your truck for work? If not I work with a guy who's cousin runs Murray's on north market. He knows powerstrokes inside and out and are good guys. I had them replace my oil pressure switch last week.
