hi im new to PSD and this forum. tips? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-22-2013, 05:18 PM Thread Starter
Thumbs up hi im new to PSD and this forum. tips?
just got my ps and adding on here shortly. i want to know what injectors and what chip to with
16 and strokin' is offline
post #2 of 7 Old 11-24-2013, 02:32 PM
andyjman's Avatar
Quoted: 2 Post(s)
first thing id do is get a bullet proof egr cooler, or delete, replace the oil cooler, change the coolant to something besides the ford gold, and if your wanting to go with bigger injectors, a chip, etc I would most DEFINITELY install ARP head studs, before you blow your head gaskets and cause issues.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #3 of 7 Old 11-25-2013, 05:16 AM
MSTR-P's Avatar
What year and motor are you working with? Lots of good info on this site.
'03 7.3 - Stock!
MSTR-P is offline
post #4 of 7 Old 11-25-2013, 07:07 AM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
Glad to have you - to the ORG!!
Check out:
Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum - Lots of good info in there. Hope you don't mind reading.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 7 Old 11-25-2013, 03:04 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 7 Old 11-25-2013, 06:59 PM Thread Starter
maroon 99 7.3l
post #7 of 7 Old 11-25-2013, 08:24 PM
andyjman's Avatar
Quoted: 2 Post(s)
Oh damn, u lucked out. Do intake and exhaust and leave it alone lol.
andyjman is offline
Tags
chips , injector buying , tires , wheels
