Hello fellow PS fans - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-18-2013, 02:18 PM Thread Starter
St33lHorse1's Avatar
Smile Hello fellow PS fans
Howdy folks! Recently bought an 01 7.3 350. It isn't running and is going to be a project for myself. I believe the problem is the HPOP, we shall see tmrw. Have used this forum many times before for a helping hand and just decided since i finally have a PS i should sign up and introduce myself a little. I'm sure questions will follow. Glad to be here!
St33lHorse1 is offline
post #2 of 8 Old 11-18-2013, 02:23 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Good to have ya! Welcome to the site!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
St33lHorse1 (11-18-2013)
post #3 of 8 Old 11-18-2013, 06:22 PM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
Glad to have you - to the ORG!!
Check out the Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
The Following User Says Thank You to SuperCrutyPS For This Useful Post:
St33lHorse1 (11-19-2013)
post #4 of 8 Old 11-18-2013, 06:57 PM
TxBoyJay's 08 KR250's Avatar
welcome, have fun with the project, definitely need to do a whole write up and step by step progress.
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
The Following User Says Thank You to TxBoyJay's 08 KR250 For This Useful Post:
post #5 of 8 Old 11-19-2013, 05:13 AM Thread Starter
Probably will! What i'm doing is taking the 7.3 engine and transmission out of my newly bought 01 350 and putting it in my 94 350. Personally i prefer the 94 style over the newer ones. For now tho I just need to get the 7.3 running smoothly.
post #6 of 8 Old 11-21-2013, 12:52 PM
1ATony's Avatar
Quoted: 44 Post(s)
Welcome to the site .
SHOP HERE FOR AWESOME
1ATony is offline
post #7 of 8 Old 11-22-2013, 07:41 AM Thread Starter
I started a thread on the progress as of yet here 1994/2001 Truck build! if you want to check it out.
Thanks Tony!
post #8 of 8 Old 11-25-2013, 03:11 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
