2001 7.3 F-250, Leaking fuel, already replaced water drain valve - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-09-2013, 06:39 PM Thread Starter
Exclamation 2001 7.3 F-250, Leaking fuel, already replaced water drain valve
My 2001 7.3 is leaking diesel around the fuel filter housing, I replaced the water drain valve today, still leaking the same. Any suggestions?
Powerstroke_Novist is offline
post #2 of 7 Old 11-09-2013, 06:42 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
is it leaking form the o-ring for the fuel filter on top.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 7 Old 11-09-2013, 08:21 PM Thread Starter
No looks like it's coming from, what, looks like the fuel lines where they connect to the housing
post #4 of 7 Old 11-09-2013, 08:39 PM
Quoted: 247 Post(s)
i would buy the o-rings kit from dieselorings and reseal the whole fuel bowl. if you dont want the kit you can get the individual o-rings.
if your in a pinch you can use a cut piece of rubber hose instead of the vibra lock orings it requires.
post #5 of 7 Old 11-09-2013, 08:52 PM Thread Starter
yea I use it as my daily driver/company truck. Do you know if it's a ford dealer only part or can I get it at a local parts house? Thanks for your input, do you happen to know the part #?
post #6 of 7 Old 11-09-2013, 09:29 PM
Colin7.3's Avatar
Either buy the ford parts for the fuel line o rings. Or go to dieselorings . Com to order them.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #7 of 7 Old 11-10-2013, 04:53 PM Thread Starter
Thanks for the input guys. After having a nights rest and daylight, I discovered the fuel filter cap is busted, seems like a common problem as well.
Tags
leaking fuel
