New guy from MD - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-05-2013, 02:25 PM Thread Starter
New guy from MD
Been poking around this site for a few weeks now and decided to register finally. From MD and just bought my 01 eclb a few months ago. 6 speed xl model. nothing fancy. already did the 05 grill and '12 tailgate swaps, soon to do the '07 harley lights. mostly joined to get some info on performance parts as i am kinda new to that part of things. thanks alot
tstorm1 is offline
post #2 of 5 Old 11-05-2013, 04:10 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 5 Old 11-06-2013, 07:51 AM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
Glad to have you - to the ORG!!
Take a look at:
Maryland Powerstrokers - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 5 Old 11-08-2013, 03:28 AM
MikesF350ps's Avatar
Quoted: 5 Post(s)
Garage
And check out the Maryland Chapter
2007 F-350 4X4, 6.0L, Leveled
ARP Studs, OEM Gasket, EGR Delete, Oil Cooler
EGT, Volt, Water and Fuel Pressure Gauges
MBRP Exhaust w/Cat & Muffler Delete
AVH P 3200 BT with Back up Camera & XM Satellite
High Idle Mod, LEDís All Around ,Viair Air System for Air Horns, XDP Coolant filtration
08 Style Mirrors, Tailgate and Bumper, SCT Livewire TS Amerihood Functional Ram Air Hood with Heat Extractions Vents and S&B Cold Intake
2015 Keystone Montana 3791RD 5th Wheel
MikesF350ps is offline
post #5 of 5 Old 11-08-2013, 03:38 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
What part of The Socialist Republic of Maryland do you hail from?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
