Hi, from the Florida Keys! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-12-2013, 09:18 AM Thread Starter
Hey everyone, thanks for the welcome! I joined this site to try and find out some cool stuff I can do to my F350! Hopefully, I can find some help here!
Thanks!
jchappe7 is offline
post #2 of 8 Old 10-12-2013, 09:23 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1034 Post(s)
Feedback Score: 6 reviews
to the ORG
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 8 Old 10-12-2013, 09:34 AM Thread Starter
Thank you!
jchappe7 is offline
post #4 of 8 Old 10-12-2013, 09:37 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 8 Old 10-12-2013, 09:38 AM
Quoted: 370 Post(s)
Originally Posted by Rattlesnake18 View Post
to the ORG
hey i'm catching up to you in post count...
Studded and Deleted
post #6 of 8 Old 10-12-2013, 09:41 AM
RIP Cam!
I don't yap as much as you do Eli, at least not like I used to.
post #7 of 8 Old 10-12-2013, 03:59 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #8 of 8 Old 10-13-2013, 09:46 AM
5fifty's Avatar
Welcome. Plenty of info and help on here.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
