hi from pa - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-04-2013, 06:55 PM Thread Starter
Post hi from pa
hi im new here and cant figure out a problem ive been having. diagnosed pretty much everything i could think of. well i replaced the injector seals, glow plugs, and valve cover gasket. its all back together but the truck will not start (sounds like when the glow plugs go on everything lacks power). ive charged the batterys about five times and they read twelve volts when i hook it all up but once the key turns they drop to about 9.47. also i checked the volts to the glows plugs its about 8.50 volts. after replacing the solenoid the truck sounds a little better but when key on wait for the wait to start light to go off there is a clicking sound coming from the number 34 relay in the distribution block. also the glow plug relay clicks on and off. motor will not crank or start all because of the voltage drop. hopefully someones had the same problem before. any input will help out going on day 4 of trying to figure it out lol. driving me crazy
white7.3l is offline
post #2 of 2 Old 10-05-2013, 05:14 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Be sure to check out all the good info in the 7.3L section.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
