new member, problem already! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-02-2013, 08:11 AM Thread Starter
Hi fellow mech's. recently joined, like what I see here. have a f-450 bucket truck with a 6.0 shuts off sometimes and wont start somestimes. replaced crank sensor and exhaust sensor. I do notice when I turn the key on I hear the injectors buzz, (it will start). when I turn key on and do not hear injectors buzz, it will not start. any ideas?
marvinrad is offline
post #2 of 5 Old 10-03-2013, 12:27 PM
1Aauto's Avatar
Quoted: 51 Post(s)
Welcome to the site
SHOP HERE FOR AWESOME
1Aauto is offline
post #3 of 5 Old 10-03-2013, 12:29 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
injector control module possibly going out , or idm relay maybe , need to get a scanner on the truck and see what codes it might have , don't throw any more parts at it until you diagnose concern further , get costly quick
ITS STOCK
SCUFFY828 is offline
post #4 of 5 Old 10-03-2013, 12:31 PM
shenanigans
junior125's Avatar
Quoted: 1748 Post(s)
Garage
if you have access to a scanner, see what the FICM volts are with it being a 6.0
Mike
2005 CCSB F250 4X4
junior125 is offline
post #5 of 5 Old 10-03-2013, 03:18 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
