Hi from Vancouver canada - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-01-2013, 07:14 PM Thread Starter
Just purchased my 03 f350 6.0 diesel about a month ago and love it. I did a
Lot of research and really wanted the 7.3 with all the bad rep about the 6.0 but that being said I got an awesome deal on it
Because of that. Truck had previous work done to it such as 3 new injectors, FICM and egr delete and no tuner with 180xxxkms. It looked good and took the chance. Wanting to do some upgrades in near future such as new shocks, blue spring upgrade, ball joints need replacing and rear leafs. Also coolant filter and flush and oil change and filters. I'm wanting to do most work myself to save some money. Really excited about my new purchase.
03 f350 is offline
post #2 of 11 Old 10-02-2013, 05:06 AM
y2kf350's Avatar
Welcome
Congrats on the new to you truck. Pics?
2000 F350 CC 4x4 Dually
Lots of stuff done - lots more to do.
y2kf350 is offline
post #3 of 11 Old 10-02-2013, 05:15 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Congrats and welcome to the site! Best advice I could give you for a 6.0 is get some kind of a monitor on your truck. Right now it cant communicate with you. And before winter gets here (thats what in about 2 weeks for you guys??) your gonna want to do a oil change and make sure your running a synthetic. I run the t6 and it makes a huge cold weather start up diffrence!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 11 Old 10-02-2013, 06:56 AM
Pac-man's Avatar
Welcome fellow Canuck. I have the 04 F350 and love the power. Unfortunately within a month of owning it the FICM went on it so the guys at BD Perfomance in Abby put a new 58V one in with a stock tune on it. Apparently my alternator went and thats what caused the FICM to fail. Since putting the new one in it runs like a dream. Oil change and rad flush once it stops raining here (which should be around May 2014).
Cheers
Martin
2004 F350 CC , Edge Insight CTS, LED cab lights, Blue Spring Mod, 58v FICM, Rotella T6 5W40
AF&AM
Pac-man is offline
post #5 of 11 Old 10-02-2013, 04:36 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 11 Old 10-03-2013, 12:26 PM
1ATony's Avatar
Quoted: 44 Post(s)
Welcome to the site
SHOP HERE FOR AWESOME
1ATony is offline
post #7 of 11 Old 10-09-2013, 10:10 AM
Welcome! Check out PDR Diesel in Langley if you need anything for your truck, Ive been dealing with them for years.
matt-jenkins is offline
post #8 of 11 Old 10-09-2013, 10:25 AM
Raul@Stealth Automotive's Avatar
Welcome to the Org....
Raul@Stealth Automotive is offline
post #9 of 11 Old 10-09-2013, 05:42 PM
Welcome. I'm located in Squamish Bc
ThcGunSmoke is offline
post #10 of 11 Old 10-09-2013, 07:23 PM
Quoted: 2 Post(s)
Welcome OP. Hope Vancouver is treating you all right. One of my favorite places in the world.
TGHill is offline
