NEW TO OWNING A POWERSTROKE - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-24-2013, 07:33 PM Thread Starter
Hello guys im new to owning a diesel truck obviously but i work construction and pull a camper around traveling i recently just bought a 04 powerstroke fx4 with 90000 miles i heard to stay away from 6.0 but i liked this truck as soon as i drove it can i get some advice thx
TXsmokeFX4 is offline
post #2 of 5 Old 09-24-2013, 07:38 PM
theplumbingmedic's Avatar
And best advice is spend about 2 days reading in the 6.0 sections , every possible answer is in there.
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #3 of 5 Old 09-24-2013, 07:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
And after those 2 days take a looooooooong nap. Let it all sink in......and then smile! Cause once you get the ol'girl runnin like it should they are awesome machines. And second, this site is filled with guys that love them and are ready to help! Welcome to the site!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 5 Old 09-24-2013, 08:11 PM Thread Starter
Thx guys ill need all the help i can get
post #5 of 5 Old 09-25-2013, 06:58 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
