Got a 96' F250 Yesterday! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-23-2013, 05:20 PM Thread Starter
Thumbs up Got a 96' F250 Yesterday!
Hello Board,
My wife and I are gearing up to do a lot of house and yard work, and we have a 1976 Catalina 25 that costs a lot to keep in the water. So, I started shopping for a truck -- something that could pull 7000lb (boat and trailer + 20%) and didn't break the bank. Looked at some towing capacity tables and settled on the 7.3l F250 from the 90s after some research.
So, found a good one yesterday and bought it: A 1996 with ~300k miles, rebuilt transmission, new tires + wheels and new starter. I watched Bill Hewit's video a couple times and took careful notes, and everything that I could access checked out. (Wasn't able to check those bolts along the exhaust manifold even with a small mirror.)
I figure I should take it to a mechanic soon to get more details on what I've got. Also to an alignment shop I'm guessing, as the tires are new but the seller didn't do alignment at the same time. Can anyone recommend shops in the Seattle area?
My first "new possession" paranoia is that our damp climate will cause rust (it came from the dry side of our fair state). The inside of the bed has plenty of paint missing, the liner is only along the bottom and some water is pooling there. Should I worry about this?
Somebody told me rain on the bare metal usually isn't enough to cause rust, but my only working knowledge is from stainless in marine environments.
The truck is a beast! Stoked to join this community too.
- Dan
dacc is offline
post #2 of 5 Old 09-23-2013, 06:36 PM
Quoted: 897 Post(s)
Feedback Score: 3 reviews
I think alligator performance is around that neck of the woods.
Careful on some of that stuff powerstrokehelp says. A lot is correct but some things will make you scratch your head. you'll find loads of info to the corresponding forums in the sticky threads.
Corey@CNCFAB is offline
post #3 of 5 Old 09-23-2013, 08:38 PM
SuperCrutyPS's Avatar
Quoted: 343 Post(s)
Garage
Glad to have you Dan - to the ORG!!
A couple of places to take a look at:
1. 94-98 7.3L Forums
2. Cascade Coal Rollers - Chapter for OR / WA members.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 5 Old 09-24-2013, 12:42 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 5 Old 01-28-2014, 11:11 PM Thread Starter
In case anyone lands on this thread, we took the truck to Duke's Truck Repair in Seattle. Had a really good experience with them.
dacc is offline
Tags
greenhorn rust hello
