New to me 04 F350 6.0 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-15-2013, 05:31 PM Thread Starter
Just thought I would say hello. I just brought home a 69K F350 6.0L from a local dealer. This is the 1st 6.0 that I have owned. I just sold a DuraMax with only 43K on it, but I needed a crew cab.
This is a totally stock truck. Is there anything that I should check out or do to ensure the best outcome from this engine?
Joe
PrisonNurse is offline
post #2 of 14 Old 09-15-2013, 05:48 PM
nick49001's Avatar
I am not sure what you plan to do with your truck so the advice i give you may not be all that you need to know. If it was me i would start by deleting the egr all together or going with a bullet proof egr install a coolant filter and make sure you keep up on the oil changes and fuel filter changes. get something like the edge insight to monitor the motor while you drive. keep track of your oil and coolant temp delta's you do not want to see more than a 20 degree difference in the two once the truck is up to operating temp if you see this its time for a oil cooler. if you tune the truck go with sct in my opinion and a million other guys opinions there the best on the market for the 6.0. if you plan to get really wild you should install head studs. and the biggest thing i think that alot of guys forget is you can't drive the truck around slow all the time you have to exercise the turbo i don't mean pound it in the ground every chance you get but i figure at least once a week take off like a bat outta hell otherwise the vgt in the turbo gets sticky. oh and welcome to the org.
03psd 6.0 ext cab 4x4
nick49001 is offline
post #3 of 14 Old 09-15-2013, 06:30 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^^nick49001 did a pretty good job! WELCOME TO THE SITE!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 14 Old 09-15-2013, 07:20 PM Thread Starter
Thanks, it looks like I have some serious research to do. I had to look up what an EGR valve was
I bought the truck for weekend use like pulling a trailer to the dump and picking up landscaping supplies for around the house.
I would also like to get a 10' pr 11' camper for taking the family camping.
I was just out driving around (wasting fuel) for fun. Wow this is one big truck. I am 6'-3" and around 230# and I almost lost in the sheer space inside this cab. My 05 Chev was nowhere near as wide.
Joe
post #5 of 14 Old 09-15-2013, 07:24 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Well if you are like me you'll get hooked on the truck and even worse hooked on this site. Their is a ton of info and some awesome people on here that cant wait to lend a hand.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 14 Old 09-15-2013, 07:27 PM Thread Starter
I was part of a Malibu boat site for years...and yeah you can kill some serious time on these sites if you want.
I have also found that enthusiast sites usually have the answers to almost any question that you can think of.
Joe
post #7 of 14 Old 09-16-2013, 08:51 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats and welcome aboard!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #8 of 14 Old 09-16-2013, 08:54 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Welcome to the forum
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #9 of 14 Old 09-17-2013, 04:56 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
Glad to have you Joe - to the ORG!!
If you haven't already, check out the Cascade Coal Rollers - The OR/WA chapter. You may find members local to you.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #10 of 14 Old 09-18-2013, 09:45 AM
1ATony's Avatar
Quoted: 38 Post(s)
Welcome to the site, it's great to have you here.
Tony
SHOP HERE FOR AWESOME
1ATony is offline
