New Guy - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-13-2013, 07:18 AM Thread Starter
Brian S's Avatar
New Guy
Hi there. Finally decided to find a Powerstroke Forum so here I am.
I've always been a Chevy guy for the most part. Then I got into the Diesel's with the Gen 1 cummins and then a gen 2 cummins. But Once the new body style Fords came out I had to have one. And with the New 6.7 that was supposed to save their diesel program I was sold. Im at around 7kmi and have added a BD 5th wheel to tow our 40' toy hauler. The truck did sag a bit until I instaled some helper bags and ever since its been a dream to tow with.
Unloaded its a bit rough and I was looking into the R4 tech rear suspension kit. Hoping to find some people with rear world experience with it here or other suggestions to soften the rid. My tires are at 65 psi. I may try 35/45.
Anyways no problems yet. I do have the sqeeling noise sometimes at idle when hot that I've been noticing. And the buzzing noise after shutting it down.
A month ago I was on the highway and noticed a different running condition. It was slight but I new something was going on and I saw it was doing a regen of the DPF. It didnt seem to be misfiring badly. Im not sure how I feel about the TSB i found on here about one cylinder head getting the Ex valves replaced. especialy since it doesnt pay well. I work at a dealer so I know how the less that glorious jobs can get pushed off onto less than glorious techs.
Anyways I'm glad to be a board and sorry for the long winded intro.
2012 F250 6.7 FX4 XLT Crew Cab Long bed (no mods)
Leveling kit with 35' General Grabbers
Brian S is offline
post #2 of 6 Old 09-13-2013, 07:31 AM
Slacker
Evil Eye's Avatar
Quoted: 207 Post(s)
Feedback Score: 4 reviews
Welcome to the site! I know of someone who installed the R4 setup and then regretted it. According to him, it was a constant harsh ride...
At least dropping your bags down will allow you to get some softness back. FWIW, I drop my bags to 0psi when I'm not towing. I know that Firestone says not to, but our suspension has enough spring to not fully compress the air bags even with a small load. I've been running them that way for probably 6 years and haven't noticed any issues with my bags.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 6 Old 09-13-2013, 07:52 AM
05krsd's Avatar
Welcome to Powestroke.org.
2005 F250 King Ranch, CCSB, FX4, 4.5 inch rough country lift, Edge Evolution tuner, studded, nitto terra grapplers 35s, custom exhaust, intake, hids. SOLD.
Looking for my next powerstroke.
05krsd is offline
post #4 of 6 Old 09-13-2013, 08:05 AM
shenanigans
junior125's Avatar
Quoted: 1492 Post(s)
Garage
welcome to the .org
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #5 of 6 Old 09-13-2013, 04:27 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 09-14-2013, 05:20 PM Thread Starter
Brian S's Avatar
Thanks guys! Lots of good info around here. I usually run the 5 lbs Firestone states but today I emptied them out. I also dropped my tire pressure from 60psi.
I went to 50/45 and what a difference. At least it's a noticeable amount and that's huge in my book. I'm going to try 45/35 since the my side walls look unedfected by the pressure drop from 60.
Anyways eventually I want a few mods.
Hoping I can get in well with a tech over at the local Ford dealer. Doubt it will happen but its a nice pipe dream.
I'd like to start with an intake and exhaust but it seems even with the smallest mods it throws red flags warranty wise.
And then since I'm in Cali the DPF will stay and I'm inclined to say I may try the Banks automind. Not sure though. I'm a speed freak and the truck does have plenty of torque but I was almost pulled on by a duramax the other day and I can't have that.
Brian S is offline
