New 08 F250 owner - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-09-2013, 08:00 AM Thread Starter
Ultra Rider's Avatar
New 08 F250 owner
Although I'm new to diesels, I'm a long time gas engine performance tinkerer and builder. In May I bought a used 08 F250 Lariat. This is my second Ford diesel (previously an 05 F250-6.0L owner). I'm obviously a diesel novice but learning quickly and in a couple instances, the hard way. My latest issue seems to have to do with the DPF. At about 150-160 miles it appears to regen causing whitish-blue smoke and heavy fumes. From what I've read in the forums, this seems to be a regen issue although there is plenty of info that says it could be something else. I would like any comments or questions to help pin this down. I'm thinking I need a DPF delete but want to be sure before I go down that path. I'm running stock and have no performance tunes so any recommendations in that area would be greatly appreciated. By the way, I drive mostly in town but I often pull a 26' travel trailer.
Ultra Rider is offline
post #2 of 4 Old 09-09-2013, 08:48 AM
Welcome to the org. Tune and delete the 6.4 and you will have a BA truck.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #3 of 4 Old 09-09-2013, 09:18 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 09-09-2013, 09:38 AM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
Glad to have you - to the ORG!!
Take a look at:
08-Newer 6.4L Forums
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
