new guy from texas - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-06-2013, 04:56 PM Thread Starter
new guy from texas
Hey guys, my name is josh and im addicted to trucks. I am new to diesels but not modding. I also have an 03lightning and been apart of lightningrodder and lightning garage. I joined psn but they dont seem to be too active.
anyways, I join with a problem with my truck. Its broke 2 injector collars?(rings that sit Round the nozzles on the oil rail) my shop cant figure out why its doin this. Im wondering if any of you gurus or master techs might have an idea. Also...the nozzles are not tight...they have some play in them. Are they suppose to be tight or whats goin on?
ID:	164257   Click image for larger version
henline_stroked06 is offline
post #2 of 6 Old 09-07-2013, 09:44 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 820 Post(s)
Feedback Score: 6 reviews
to the ORG
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 6 Old 09-07-2013, 11:08 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 6 Old 09-09-2013, 08:12 AM
Welcome Josh to the org. I would post the problem you are having in the 6.0 section, there are many members that can answer your questions there. Good luck on finding the problem.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #5 of 6 Old 09-09-2013, 08:28 AM
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
Glad to have you Josh - to the ORG!!
Good looking truck!
A couple of places to take a look at:
1. 03-07 6.0L Forums
2. Lone Star Powerstrokes - Texas Chapter. Maybe you can connect with members local to you.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #6 of 6 Old 09-09-2013, 10:05 AM Thread Starter
Thanks guys ill check out those sections
