Hello from Jacksonville, FL - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-29-2013, 05:49 AM Thread Starter
dnaber's Avatar
Hello all, Just want to take a sec to introduce myself. I'm a long time Ford truck owner and just upgraded to an 09 F250 , 6.4, Lariat 4x4. Looking to ask plenty of questions and help to provide some answers.
Don Naber
USAF (Retired)
Middleburg, FL.
God Bless America, And All That Serve This Great Nation
dnaber is offline
post #2 of 7 Old 08-29-2013, 05:58 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site and for your time!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 08-29-2013, 06:19 AM
HarvestingInternationally's Avatar
welcome to the org
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #4 of 7 Old 08-29-2013, 09:17 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Welcome Aboard, I'm a fellow Floridian myself, Ormond-By-The-Sea!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 7 Old 09-03-2013, 09:02 AM
5fifty's Avatar
Florida here too..
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #6 of 7 Old 09-03-2013, 09:57 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 823 Post(s)
Feedback Score: 6 reviews
to the ORG
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 7 Old 09-03-2013, 09:58 AM
dieselmatt's Avatar
Quoted: 3 Post(s)
I used to live in Jax. Might be headed back that way for the next PCS.
dieselmatt is offline
