Just joined, Mission British Columbia - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-28-2013, 04:15 PM Thread Starter
Pac-man's Avatar
Hello, in the process of buying a 2004 F350. We weren't in the market for a Ford, we were actually looking for a Nissan Titan but came across the 350. It has 120,000 KMs . Part of the deal was that he had to replace the front left wheel bearing, replace fuel and water filter and fresh oil so I get to pick it up next week,
Looking through the forums here I see that there is a number of preventative measures that can be done to prolong the life of your truck but trying to read every post and not knowing half of the lingo its hard to get a list of things to do. The term BULLETPROOF comes up a lot. YouTube has some tips on how to clean the EGR valve and do some other DIY.
The head bolts have been replaced with the longer ones, so he tells me that I don't have to worry about the head.
Is there anything you think I should know about my truck???
Cheers
Martin
Pac-man is offline
post #2 of 5 Old 08-28-2013, 06:06 PM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
Glad to have you - to the ORG!!
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 5 Old 08-29-2013, 05:26 AM
HarvestingInternationally's Avatar
welcome to the org...delete the EGR if u can youll be happier
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #4 of 5 Old 08-29-2013, 06:34 AM
y2kf350's Avatar
Welcome from a fellow lower mainland member.
2000 F350 CC 4x4 Dually
Lots of stuff done - lots more to do.
y2kf350 is offline
post #5 of 5 Old 08-29-2013, 08:13 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
