new from TX/CA/afghanistan - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-25-2013, 05:53 AM Thread Starter
cmagee's Avatar
how's it going guys. just picked up the truck in my sig today. i missed these engines so i sold my cummins and made my way back. active duty US Navy currently deployed to afghanistan, stationed in california, originally from Texas. look forward to learning a lot
Colten
03 RCLB 4x4 6spd 6.0, GT3788VA, AFE stg 2, deletes, oil cooler, p/p heads/valve guides, ported intake manifold, updated springs, oil o rings and fittings, 58v FICM with mild flash, blue spring upgrade, 6.4 banjo bolts, 155/75 injectors, FASS lp, 3"dp to 5" exhaust, studs, autometer boost, pyro, fuel, 550hp clutch, 8" lift, 37x15 toyo mt's, 485hp/912tq on stock tuning
cmagee is offline
post #2 of 9 Old 08-25-2013, 05:57 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site! Thanks for what you be doin and keep your head down!!! Were the heck is Pipe Creek?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 9 Old 08-25-2013, 06:21 AM Thread Starter
cmagee's Avatar
tiny tiny town near bandera. if you don't know where that is (not trying to be a smart a$$), it's between san antonio and kerrville. just curious, how do you get the military member logo?
Colten
cmagee is offline
post #4 of 9 Old 08-25-2013, 07:14 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Navy Retired here.
Thank you for your service and get home safe to enjoy that truck!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 9 Old 08-25-2013, 07:21 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 903 Post(s)
Feedback Score: 6 reviews
to the ORG
Thank you for your service!!
As far a the military badge, go into your user CP, look to the left at the menus, click on group memberships, then you will get a screen that will have a military usergroup option, click on join group, and then you will need to provide some of your info/credentials. One of the staff members that is in charge of the group will get you taken care of from there.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 9 Old 08-25-2013, 11:05 AM Thread Starter
cmagee's Avatar
thanks jeff!
Colten
cmagee is offline
post #7 of 9 Old 08-25-2013, 11:24 AM
RIP Cam!
Quoted: 903 Post(s)
No problem man.
post #8 of 9 Old 08-25-2013, 11:00 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
Glad to have you Colton - to the ORG!!
Thanks for your service.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #9 of 9 Old 08-26-2013, 03:55 AM Thread Starter
cmagee's Avatar
thanks everyone. nice to know there is this kind of feedback. definitely didn't get this kind of support from the last forum i was a member of, not to name any names lol
Colten
cmagee is offline
