info on Excursions? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2013, 04:34 AM Thread Starter
info on Excursions?
Hey folks, long time Ford guy but just joined as I picked up a 6 liter Excursion. Looking forward to learning from you all. Anyone that's done an Ex suspension work, I can use the tips. Considering a radius arm D60 swap, but my just do springs an a new gear box. Depends if my ABS will still work with the swap. Info appreicated. Have a good one.
fastang50 is offline
post #2 of 7 Old 08-20-2013, 04:36 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Welcome u can go yo the ex part of the forum and check out suspension I have a bit of exp my best friends ex was on 40s and a 10 inch lift
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 7 Old 08-20-2013, 06:53 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 7 Old 08-20-2013, 09:29 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We mod Excursions. We have come up with suspension and handling fixes. We also have what's needed to do '05 up axles etc.
CT Performance, Inc. is offline
post #5 of 7 Old 08-20-2013, 11:46 AM
1ATony's Avatar
Quoted: 42 Post(s)
Welcome to the site
SHOP HERE FOR AWESOME
1ATony is offline
post #6 of 7 Old 08-20-2013, 12:06 PM
SuperCrutyPS's Avatar
Quoted: 310 Post(s)
Garage
Glad to have you - to the ORG!!
Check out the 6.0L Forums (Includes an Excursion forum):
Ford 03-07 6.0L Powerstroke Forums - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #7 of 7 Old 08-20-2013, 12:48 PM
jaysshortbus's Avatar
Jay
jaysshortbus is offline
