Oil in Coolant - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-16-2013, 06:32 PM Thread Starter
Oil in Coolant
Have a 6.0L engine that is pumping oil out of the coolant reservoir. Does this engine have and oil to water cooler? Is this a gasket failure?
Thank you,
Kevin
kbaldwin is offline
post #2 of 3 Old 08-16-2013, 07:55 PM
Quoted: 908 Post(s)
Feedback Score: 3 reviews
Yes it does, and that's usually the culprit.
In order for you to get better help, repost this in the 6.0L forum.
BTW, welcome to the site. :thumbup:
Corey@CNCFAB is offline
post #3 of 3 Old 08-17-2013, 01:44 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
