New Guy - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-11-2013, 10:09 AM Thread Starter
New Guy
Hello All,
I picked up my new truck three weeks ago and have enjoyed the first 6200 miles.
Looking forward to reading about others experiences here.
2013 F250 Crew Cab 4x4 SB
RTHMVR is offline
post #2 of 5 Old 08-11-2013, 10:28 AM
mastrkee's Avatar
Quoted: 3 Post(s)
Welcome to PS.O
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 5 Old 08-11-2013, 10:32 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 953 Post(s)
Feedback Score: 6 reviews
to the ORG
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 5 Old 08-11-2013, 10:35 AM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
to the ORG!!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #5 of 5 Old 08-11-2013, 12:27 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
