F350 Mirror Extenders - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-06-2013, 06:27 PM Thread Starter
Big Papa 03 dually's Avatar
Does anyone know of a good set of extenders for the big tow mirrors, I pulled mine out all the way and still can't see down the side of my trailer.
Big Papa 03 dually is offline
post #2 of 11 Old 08-06-2013, 06:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im in the same boat with you on this. After lookin at the mirrors on the Dodges I would of figured that FORD would take the hint and put some SERIOUS mirrors in.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 11 Old 08-07-2013, 07:31 PM Thread Starter
I was thinking about it and woundering if I could pull the mirror and build a spacer behind the mounting bracket I think 2" would do it. I pulled the mirror out and set them at 90* but they don't lock there. Any thought?
post #4 of 11 Old 08-08-2013, 01:16 PM
1ATony's Avatar
Quoted: 33 Post(s)
to the site
SHOP HERE FOR AWESOME
1ATony is offline
post #5 of 11 Old 08-10-2013, 06:51 AM Thread Starter
Thanks been a member since 2009, but just not on very much...
post #6 of 11 Old 08-25-2013, 08:09 PM Thread Starter
Can anyone tell me how far out the 08 style mirrors stick out or are they just better because 04 style turn in at the top. Just a messurement from glass to top end of mirror.
Thanks
post #7 of 11 Old 08-25-2013, 08:29 PM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
I think the 05 mirrors might come out an inch or 2 further because the "arms" are straight. But even if they don't, man, you can see SOOO much more with them
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #8 of 11 Old 08-27-2013, 11:38 AM
Old member, first post.
Hello all. I've been lurking here and other diesel sites and can usually find info that I need without posting. I have a Arctic Fox cab over and dolly tow a old Bronco when hunting and camping. On the flats there isn't any problems but when pulling high passes the trans has heating issues, 240-250. I disabled the stock trans by pass line and run directly through a after market trans cooler (third one) in series with the stock cooler. After reading more on this heating issue I decided to try the torque converter lock up switch which seeme to be a pretty common mod to help with this problem. Tapping into the purple/yellow stripe wire at the trans and grounding it with a in line switch there is no difference at all. When activated it's supposed to kill the engine at idle. I've tried two switches, one lighted and one plain and no difference, the engine just keeps running. There is current flow when activated but no effect on the trans. This is a Ford rebuild with about 40,000 miles on it and has had no issues at all. Just wondering if maybe there are issues with the torque converter? My next step would be to get one of the after market programmers but would really like to keep it simple.
I'm stumped and running out of time. Ideas? Thanks.
kermit101 is offline
post #9 of 11 Old 09-30-2013, 08:14 PM Thread Starter
08 style mirror did the trick, they are bigger and with the arms out I can see much better. Thanks to A1 auto
post #10 of 11 Old 09-30-2013, 08:16 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
How much they run ya? Did you get the manual or fully powered ones?
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
