My new 2001 f250 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-29-2013, 03:25 PM Thread Starter
jvanwalsen's Avatar
My new 2001 f250
Hello, everyone. I bought this on Friday. Pro comp 4 inch lift, new garret turbo and pedestal, new transmission lines, new oil cooler. Truck has 218000 miles. So far this truck is everything ibthought it would be. Just powerwashed the engine bay and the underside., to see if there are any leaks. Truck was undercoated and from texas not a spec of rust on the body and the frame aint that bad either. Leather interior that is not all ripped up.
ID:	132130   Click image for larger version
ID:	132138   Click image for larger version
jvanwalsen is offline
post #2 of 7 Old 06-29-2013, 04:04 PM
HarvestingInternationally's Avatar
Nice truck welcome to the org
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 7 Old 06-29-2013, 06:19 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 7 Old 07-05-2013, 10:45 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
What's on the end of that K&N pipe?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #5 of 7 Old 07-06-2013, 03:59 AM Thread Starter
jvanwalsen's Avatar
A K&N air filter?
post #6 of 7 Old 07-06-2013, 11:02 AM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
welcome to the org
Mike
"The Iron Pig"
mudrunninpig is offline
post #7 of 7 Old 07-15-2013, 02:29 AM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
