New diesel owner--2006 F250 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-29-2013, 09:19 AM Thread Starter
I found a one-owner 2006 F250 PS Crew FX4 with 49k miles on it and will be picking it up this afternoon from a reputable Ford dealer after having studied the Oasis report and Autocheck/Carfax. I have done a metric shiz-ton of research on the 6.0L and am adequately scared to death of the problems it has potential for. I am also prepared, thanks to forums like this one and Youtube, to deal with those issues if they ever arise. Given I am not a racer, off-roader, or construction worker and this truck is going to be used for very light duty, I think I should be okay. Anyway, thanks for a great forum.
Cheers,
Lee
ezturbo is offline
post #2 of 9 Old 06-29-2013, 09:34 AM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
welcome to the org!! my truck just hit 49k miles as well
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #3 of 9 Old 06-29-2013, 10:11 AM
BrianSnelgrove's Avatar
Keep something in mind when you are looking at message boards dealing with these trucks/motors. Most of what you will read are from people having problems and can leave you with a really bad impression. I have had my '06 for about 5 years now and I have put about 60k on it. It has let me down one time - IPR went bad - but it was fairly easy do diagnose and repair. I did some of the basics a few months ago - EGR delete, oil cooler, SCT, coolant flush/ELC refill, etc - but only did them because I was starting to have low EGR flow codes. Honestly, I consider most of what I have done to the truck as maintenance work. I have loved mine and it is a pleasure to drive every day.
If you are not going to do any heavy work with the truck just be sure to stay on top of the regular maintenance - oil changes, fuel filters, coolant flushes, etc. - and pick up a ScanGuage II to monitor EOT and ECT from time to time so you are sure the oil cooler is not clogging up.
BrianSnelgrove is offline
post #4 of 9 Old 06-29-2013, 04:07 PM
HarvestingInternationally's Avatar
Welcome to the org
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #5 of 9 Old 06-29-2013, 06:19 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 9 Old 06-29-2013, 08:18 PM Thread Starter
Thanks. Routine maintenance is nothing new to me, but I understand it is more critical with this engine than with most others. I was actually searching for a good monitor device.
ezturbo is offline
post #7 of 9 Old 07-12-2013, 02:43 PM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #8 of 9 Old 07-12-2013, 02:52 PM Thread Starter
Thanks. I should probably update this thread to say that I added the ScanGauge right away and have since also added a coolant filter. I will be flushing with Restore and Restore+, refilling with Cat ELC, and replacing the thermostat this weekend. I am hoping this will give me a good baseline for the cooling system. I plan to change the oil over to Rotella T5 this Fall. So far, the honeymoon is going great and I am having fun tinkering!
2006 F250 Lariat Crew Cab Short-bed FX4 6.0L Auto
Bone stock except for:
ScanGaugeII
Sinister CFS
ezturbo is offline
post #9 of 9 Old 07-12-2013, 02:57 PM
Quoted: 2 Post(s)
Welcome!
They're not that bad... these trucks give warnings long before something really bad goes wrong. Just monitor the temps with a scangauge or similar device and keep an eye out for warning signs (coolant contamination, leaks on the ground under the truck, etc.)
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
