newby with a ford F350 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-20-2013, 06:22 AM Thread Starter
Hi everyone, my name is Darren and I have joined the site to get hints on how to work on my F350 with out to much out in diagnostic equipment and specialty tools. Currently my truck will start but as soon as you step on the throttle it starts missing and blowing black smoke. Not sure if it is an injector or the turbo. When I find the rite forum I will post more but in the mean while I am happy to be a member and hope for lots of good advise.
Darren
dmcdowell is offline
post #2 of 17 Old 06-20-2013, 07:34 AM
Is your check engine light coming on at all?
95 f250 flatbed 7 position chip with straight pipe turbo back. Everything else is stock!
BEMAC is offline
post #3 of 17 Old 06-20-2013, 01:19 PM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
Glad to have you Darren - to the ORG!!
More info about your truck would help us point you in the right direction. I'm sure you'll find good info!!
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #4 of 17 Old 06-20-2013, 04:01 PM
c69ss396's Avatar
get the AutoEnginuity Total Ford Enhanced Bundle, it will be your best investment in reguards diagnostic equipment.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 17 Old 06-20-2013, 07:07 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 17 Old 06-20-2013, 07:08 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Welcome!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #7 of 17 Old 06-20-2013, 07:39 PM
usteffenhagen's Avatar
Have you taken apart your turbo/ checked to see if there is oil keaking from it?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #8 of 17 Old 06-21-2013, 08:38 AM
HarvestingInternationally's Avatar
Welcome to the org
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #9 of 17 Old 06-21-2013, 01:01 PM
1ATony's Avatar
Quoted: 36 Post(s)
SHOP HERE FOR AWESOME
1ATony is offline
post #10 of 17 Old 06-21-2013, 05:58 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
welcome to the org
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
