Okie Newbie with my first PowerStroke - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-01-2013, 09:49 PM Thread Starter
OrangeBlood's Avatar
Hello to everyone out there! I just picked up a new to me 2005 6.0L PowerStroke It is mostly stock except for aftermarket wheels and tires, muffler and catalytic converter deleted and a 6" tip? I want to modify or (bullet proof) it as much as I can? I am married to a great woman, but she wants to keep spending to a minimum and I want to take it to the max, so I figure somewhere in the middle is where I will be? The only thing I have done so far is change the oil and filter and will be changing out the fuel filters very soon! I've been lurking for a bit and have noticed a lot helpful folks on here with some nice rigs, keep up the good work guys and gals!
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
37x13.50x22 Nitto Trail Grapplers
SCT tunes from Innovative Diesel
and some other stuff a work in progres blahblahblah
OrangeBlood is offline
post #2 of 6 Old 04-01-2013, 10:18 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
I'm single, so I don't really know where the mods will stop if I was you. If it's running great dont mess with her, that's if you don't tow or drive it hard. I would delete the egr cooler though as preventive maintenance unless it's been done already.
'086.4LDiEsEl' is offline
post #3 of 6 Old 04-01-2013, 10:19 PM
Quoted: 2 Post(s)
oh and
post #4 of 6 Old 04-02-2013, 03:07 AM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 6 Old 04-02-2013, 04:37 AM
481-SCO's Avatar
Welcome to the org from a fellow okie
Name is Allen
97 F350 Crew Cab 7.3 5 speed 6 position TS chip,Glow Shift gauges Boost,fuel pressure, and EGT has a flat bed.
Keep Oklahoma Powerstrokes alive
481-SCO is offline
post #6 of 6 Old 04-03-2013, 03:05 PM Thread Starter
Thanks fellas! Yes sir 086.4, it still have the EGR cooler in it! Would it be better to do a delete kit or just plug the ends of the cooler? If the same cooler is plugged and bolted back in, all up pipes and such would be fastened back just as it was? The delete kits I have seen don't bolt on in the same fashion and having possible leak points? How have the delete kits worked for those of you that have done it? I really would like to do this in the best way possible? Any suggestions or experiences would be greatly appreciated!
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
