Hello all - - Ford Powerstroke Diesel Forum
Old 01-18-2008, 07:57 PM
Hello all -
My name is Dana Joe, I have a '99 F-350 4x2 Western Hauler Crew Cab.
Fellas, I done run the thing out of fuel.
Yeah, I knew better...but, I tried to stretch it a little too far. I came up short.
I spent the last two hours trying to start the thing - ether assist through the intake, topped the bowl off with fuel and transmission fluid (an effort to try and create vacuum as such to draw fuel into the bowl)...to no avail did any of these things work.
Can anyone offer assistance as to what I should do?
Any assistance would be most appreciated!
Your humbled new member,
Dana Joe
Old 01-18-2008, 08:08 PM
to the ORG!!
Old 01-19-2008, 03:53 AM
Welcome to the org and someone will be along in a while to help you out.
Old 01-19-2008, 04:57 AM
Almostdunfukinwidit
welcome to the site. first thing i suggest is stop using ether, use wd40 instead ether and glow plugs dont mix well. next make sure you have at least 10 gallons of fuel in the tank. Cycle the key several times without turning the vehicle over to make sure the fuel is flowing up to the bowl. Then turn it over and try to start it. It will take a little while for it to run right because it has to bleed the air out of the system.
Hope this helps
Old 01-19-2008, 04:59 AM
im fat and ugly
welcome aboard
Old 01-19-2008, 05:08 AM
Hope you get it staightened out soon
Old 01-19-2008, 05:37 AM
WELCOME TO THE ORG DANA JOE!!
Old 01-19-2008, 08:13 AM
Dave - thank you for the advice, I'll try that. I'll report back as to my results...again, thank you for your help.
Old 01-19-2008, 08:46 AM
back to business
Old 01-19-2008, 09:21 AM
Good luck Dana!!
