Renegade 6.0 Diesel Owner - Ford Powerstroke Diesel Forum
Old 02-25-2013, 10:29 AM
Hey guys, I bought this 2007 F250 PSD Renegade in Oct 2011 as a future puller of a 5th wheel. After my first camping trip in July 2012 I returned home and popped the hood to check the fluids. To my horror I discovered the dreaded "white residue" all over. Yup, it appears the owner before me had blown the head gaskets while towing horse trailers and decided to trade the truck in. Not know anything about diesels I bought this baby because of her beauty and low mileage (58000). Well now its mine to fix and thats just what im going to do. After months of research and quotes from dealers and local shops I have decided, after seeing the Under the knife sticky, that I will be taking this on myself. I hope to begin in the late spring once I have all the parts. I found this site to be the most helpful after reading other threads so I decided to join. I cant wait to get started, enlist your help and post pics of the upcoming "A newbie tackles the 6.0 gaskets series" Thanks in advance for the help I know I will receive.
[IMG][/IMG]
Old 02-25-2013, 10:32 AM
And good luck with the repairs
Old 02-25-2013, 10:34 AM
Truck took all my money
damn good looking truck. sorry to hear about your misfortune with the head gaskets. we will be here to help you through it! goodluck. and welcome to the website!
Old 02-25-2013, 10:35 AM
Illiana Chapter Director
It's a fun job. I'm doing an Excursion right now. Before you get to into it, check and make sure you don't just have an EGR cooler issue, if you haven't already. You might get lucky and only have to do that and an oil cooler.
Old 02-25-2013, 10:37 AM
MAD - Modification Addict
Feedback Score: 7 reviews
^ What Doug said. Check out the EGR cooler unless it was deleted. Either way you will probably end up doing head gaskets but it's not bad at all. It looks WAY worse than it really is. LOL the 6.0's bark is worse than it's bite.
Old 02-25-2013, 11:08 AM
I to was hoping for that. Ford did the coolant pressure test while driving and said they hit close to 20 psi. During my research I purchased a PLX Kiwi OBDII scanner and linked it with Torque Pro on my android. I monitored my Oil and Coolant temps during normal driving and they stayed within 5 degrees of each other. So until I perform the coolant pressure test myself I have to take thier word for it.
Old 02-25-2013, 11:10 AM
Thanks Bryan, I will be leaning on you quite a bit in the near future. Thanks for the great walkthrough. I had all but lost hope and then I read that thread. Thanks again
Well, good luck on the repair then. It's not too bad, just a TON of parts to take off.
Old 02-25-2013, 11:16 AM
No problem bud. Just take a look in the engine valley on the left side under the turbo. If you see a round tube that U's back around to the oil cooler housing you have a EGR delete. If you see a square cooler looking thing that goes to the back and connects to the up pipes than you have an egr cooler and I would test it first.
How you do that is to start the truck and run it up to operating temperature. Then shut it down and wait 30 mins then come back out and start it again. If it smokes white out of the exhaust you have a ruptured EGR cooler. Replace or delete immediately. If you don't have a EGR cooler and instead have a EGR delete installed than your head gaskets are shot and I wouldn't drive it anymore until it's repaired or you risk cracking your heads.
Old 02-25-2013, 11:22 AM
I will look when I get home from work. Thanks
