| Introductions This is the place that you introduce yourself |
wont start
im new here and i hope i can get some help i have a 95 psd it wont start i give it either and it runs soon as either stops truck does too fuel filter changed gettin fuel wont run what do i do next my last truck was a idi to be honest i should have kept it any help plz thank you
to the ORG!!As far as the problem someone more knowledgable than me will be along to help. |
Welcome to the ORG.!Have you checked the fuel pressure? Try replacing the CPS, they are only about $25 from Ford. It is one of the most common problems on 7.3's. |
I would check the oil level in both the engine and High Pressure pump. The level should be within a inch of the top. as Derrik said could also be the cps.
Also, are all you indicator lights and tack working? Jim |
Welcome to the site! I hope you get it running soon.
Please don’t ever use either, is the tach moving while its cranking or running, if not it is most likely the CPS, heck for 5 minutes work and $20 why not try it. Does the wait to start light come on with the key? If not this is a sign of the computer loosing power or being fried, usually the fuel heater needs to be unplugged and a fuse replaced.
Welcome to Powerstroke.org
