never owned a diesel. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-05-2007, 05:10 PM Thread Starter
Hello members! Thanks for having me. I am a new member that just purchased a 96 f-250 7.3 with 67k miles. Recently it has been hard starting (temps around 32f, high humidity) and doggin' it first trip in the morning. When i give it throttle, initial response is fine, then rpm drops a few hundred and the engine sounds very throaty and loses power. The strange thing is it wont do it 2 hours later. havent added chemicals to fuel yet and am plugging in 2 hours before start. Sound familiar to someone? all hlp is appreciated. Thanks all!
baldguy is offline
post #2 of 12 Old 11-05-2007, 05:11 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
to the ORG!!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #3 of 12 Old 11-05-2007, 05:17 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Welcome to the ORG.!
Do you hear a hissing sound when it is losing power? It is probably the EBPV closing to warm the engine. Try unplugging the two wire connector under the inlet side of the turbo compressor housing to see if it stops.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 12 Old 11-05-2007, 05:18 PM
I have excessive flatulance!!
Diesel Nick's Avatar
Send a message via AIM to Diesel Nick
2002 F-250 4x4 CC 7.3L DIESEL SOLD
Mods
Edge Evo
Edge Juice W/ Attitude
4 Inch Turbo Back Exhaust Straight Pipe
DIY Tymar Intake
Foil Delete
Recon Light Strip
Diesel Nick is offline
post #5 of 12 Old 11-05-2007, 05:21 PM
Raul@Stealth Automotive's Avatar
Welcome to the Org....
Raul@Stealth Automotive is offline
post #6 of 12 Old 11-05-2007, 05:47 PM
Is it even worth it???
ABOBB's Avatar
Welcome to Powerstroke.org
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #7 of 12 Old 11-05-2007, 05:53 PM
SMKSTAX's Avatar
WELCOME TO THE ORG!! 67,000 miles that's barely broken in!!
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #8 of 12 Old 11-05-2007, 10:45 PM
Has anyone seen my husband?
Tracie's Avatar
Welcome to the site....
Tracie is offline
post #9 of 12 Old 11-05-2007, 11:39 PM
The Fat Mod
Logan's Avatar
Maybe someone can give ya some help here in a bit.
Logan is offline
post #10 of 12 Old 11-06-2007, 08:35 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
