95 7.3 powerstroke relay/starter issues - Ford Powerstroke Diesel Forum
Old 11-02-2007, 01:14 PM
Hi my name is Jenn and I have a 95 7.3 f250 turbo diesel. I have read alot of posts about the 7.3 relay issues so I just tryed to replace my relay, and when I put the new one(a napa Part) in, my starter wont turn over so I then put back in my old relay and the starter works. I am at a loss as to what to do. I tryed using my voltmeter to check across for power and am not sure why I get 12.7v across between the two large posts on both of the relays, If it is a relay shouldn't it only switch on when the key is on to the wait light? Any help would be appreciated.
Old 11-02-2007, 01:15 PM
Desert Shield/Storm Vet
Are you changing the starter relay or the the glow plug relay?
Old 11-02-2007, 01:19 PM
I believe i am changing the glowplug relay. do they look the same?
Old 11-02-2007, 01:20 PM
Yep the glowplug is on the front top of motor passenger side. Its a 4 post relay.
Old 11-02-2007, 01:29 PM
The only relay I can see is on the passenger side, to the rear of the battery, beside the antifreeze resevour, mounted to the side of the chassie but it only has 3 posts? Am I just not seeing the glowplug relay?
Old 11-02-2007, 01:33 PM
Yeah thats your starting relay for the starting circuit. The glow plug relay should be where I said it was near the fuel filter housing. Give it a look one more time should be there
Old 11-02-2007, 01:39 PM
Thanks so much just found it under the turbo cover. hope this is the problem Thanks again. ~Jenn
Old 11-02-2007, 01:42 PM
You bet yeah sorry I should have told you about the plastic engine cover
Old 11-02-2007, 02:32 PM
The Lady Mod
Send a message via Yahoo to Granny
Hello Jenn and welcome to the site! This site is full of great folks who are more than willing to help. All you have to do is ask. I hope you were able to fix your problem. Enjoy your time spent here and make yourself at home.
Old 11-02-2007, 04:05 PM
Is it even worth it???
Welcome to Powerstroke.org
