| Introductions This is the place that you introduce yourself |
New from north mississippi
Glad to join
I own a 2004 f250 with a 6.0 that has been giving me a few problems lately I hope to find all the answers I'm looking for, boggle some brains and talk with a few good people along the way. Thanks |
what problems?
to the ORG!!
Started missing and knocking like it had a bad injector
Scanned it and found injector codes. No ficm code. Did a cutout on all injectors and couldn't communicate with 2,4,6 and 8 so I thought it was the wiring harness. Checked harness, checked ficm voltage, cleared codes and still came back with number four Low voltage. Pulled 2,4,6 and 8 injectors checked all prongs and seals (Replaced number four) put everything back together and started truck Still had a bad miss and no power. Done a Relative compression test and cylinders four and five were low. Pulled the new #4 injector back out and pulled number five out. When I pulled the stand pipe from the right side it had a little rust on it.(looked like rust) when I pulled number 5 injector it looked like it had rust bout mid way of the injector. For some history on this truck. I've had to change the egr valve, egr cooler, oil cooler and coolant reservoir. |
